Home Assistant lanserar Amber
Home Assistant Amber introduction and Q&A
Några snabba Specs:
Uppgraderingsbar hårdvara, använder sig av Raspberry Pi Compute Module 4.
ZigBee 3.0 och Matter-kompatibel.
M.2 för expanderbar lagring alt. Google Coral AI-accelerator.
En variant som kan strömförsörjas via POE.
Features & Specifications
Carrier board for Raspberry Pi Compute Module 4 (CM4)
CM4 board-to-board connector
Supports direct boot from NVMe devices (e.g., for CM4 Lite)
12 cm x 12 cm
Compatible with all 32 variants of CM4
Quad-core Cortex-A72 (ARMv8) 64-bit / 1.5 GHz
Up to 8 GB RAM
Up to 32 GB eMMC
Regulatory approval does not cover wireless variants
Integrated smart-home wireless (Silicon Labs MGM210P Mighty Gecko Module)
Supports Zigbee 3.0, OpenThread, and Matter
2.4 GHz radio with TX power up to +20 dBm
1024 KB flash program memory, 96 KB RAM data memory
Pre-installed with Zigbee 3.0 firmware (EZSP), can be upgraded
Expansion slot
For NVMe SSDs or Google Coral AI Accelerator (M-Key)
M.2 socket M-Key
Supports 2230, 2242, 2260, and 2280 modules
PCIe x1
Gigabit Ethernet
2 x USB 2.0 Type-A host port
1 x USB-C 2.0 device port (Silicon Labs CP2102N USBXpress USB bridge)
UART mode (default): debug USB-to-serial adapter
USB mode: CM4 USB 2.0 interface for USB recovery
High-quality stereo audio DAC
2 V RMS line-out on 3.5 mm audio jack
SNR 106 dB
2 x Push button
Red: Factory reset
Blue: To be determined
RTC backed by CR2032 battery
Status LEDs (can be powered off during regular operation)
Green: Power
Red: Disk usage
Yellow: Home Assistant system state
Power
12 V / 2 A through barrel DC power jack (5.5 mm x 2.1 mm)
Ethernet: PoE+ IEEE 802.3at-2009 Class 3 or 4 (selectable via jumper)
Typical power usage
Idle ~1.5 W
Idle with NVMe ~2.5 W
Load ~5-9 W
Enclosure
123 mm x 123 mm x 36 mm
Translucent injection-molded polycarbonate plastic
Tool-free assembly
Accommodates custom heat sink (included)
Källa:
