<p>Eltako har lanserat en smart liten dosa som går att placera bakom strömbrytaren.</p>
Sådana här dosor har det funnits flertalet av tidigare men det exceptionella med den här är att den fungerar med alla stora röstassistenter.
Eltako is now presenting four Series 64 actuators for flush mounting: a wireless universal dimmer actuator FUD64NPN/110-240V, a wireless impulse switching relay FSR64NP/110-240V, a wireless impulse switching relay FSR64PF/110-240V, as well as a wireless shading actuator FSB64NP/110-240V. The types FSR64NP and FSB64NP are additionally equipped with a power metering IC for the power measurement of the connected consumer
Funktioner:
- The next evolution in smart home control.
- Latest generation IoT products.
- Teach-in / switching / dimming with EnOcean wireless and wired pushbuttons, as well as via smartphone directly via the WiFi home network.
- Own IP address for remote Internet access.
- Smartphone connections highly encrypted.
- WiFi, Bluetooth and EnOcean can be deactivated for offline operation.
- Apple certified and can be taught-in into Apple HomeKit immediately, including voice control.
- Can be updated from the start. Advanced firmware can be imported via a WiFi with a smartphone and the Internet.
- You can update the firmware for Google Assistant, Amazon Alexa and other systems soon.
- You can save the settings via backup and also import them into other actuators of the same type.
- Control functions with EnOcean and wired buttons are compatible with the Series 61 and 62, the Tap-Radio and the Series 14.
- You use the optimized tap functions to teach-in using a pushbutton.
Tack till Micke Rehn för tipset
